Fitting Smart Tabs to a new SX18
5 Attachment(s)
I am about to fit some smart tabs to my new SX18 with swim platform.
If anyone has done this before, can they offer me any tips? For people reference these are the tabs..... They are very light weight. In the UK they cost £150 :eek_animated: which is more than they are in dollars - and the exchange rate is meant to be in our favour:shakehead: Paying $300 for very light weight plastic seems extreme.. so I hope they work. I may have some issues with the positioning of them due to the swim platform leg and or the depth sounder, but I will truly only know when I get to the boat this weekend. I contacted nauticus about fitting them and this was their response Quote:
The 3M4200 is the one you will find more often on this side of the pond but yes, they are equivalent.
I'm pretty sure there's been a couple of others do this job with swim platforms so hopefully they will chime in. As for the 'light weight plastic' they will work fine with your 18' boat and John @ Nauticus stands behind his product. The guys here with the heavier 22 footers and above need the S.S. versions or even hydraulic/electric trim tabs to handle the extra stress. |
I added a swim platform after the tabs were already on. I ended up having to "lean" the support bars in order to clear the tabs. Unfortunately, I don't have any pictures (my wife was out of town that weekend with the camera) of the install.
The tabs are quite flexible as far as mounting locations, I don't think you'll have an issue finding a place suitable. |
I quite believe the are strong enough, it was just the $300 for some moulded plastic.... but I guess I am paying for an import, and they are in business for a profit... still if they work I will be happy |
Re: Fitting Smart Tabs to a new SX18
1 Attachment(s)
I just bought a 1998 Mariah 204 Jubilee Deck Boat, 20’ – 4.3 liter, V-6 motor
I would like it to plane out better (See picture attached) Where should I mount these? 1, 2 or 3? |
You should try installing them as close to the outer edge as possible. However, position "1" will probably have interference between the actuators and the design of the transom. Position "2" should work fine.
Position # 2 will likely work best. Here's a link to Nauticus' installation instructions/video/photos.
| All times are GMT. The time now is 03:14 PM. |
