Fuse box location- Shabah 238
Do"s anybody now where the fuse box on a 328 might be?, I can't find it ,the bilge pump the one I want!
Re: Fuse box location- Shabah 238
Fuse boxes are nearly always located up under the drivers console on the starboard side. Check the connections (clean & reconnect) at the bilge pump and also check to see if you have power going to the pump when the switch is turned on.
Thanks Mikeyt I took the back panel off but could see it,i will look lower down tomorrow. The pump was left on for about 3 hours, heard it going when I went back to it to put the hood on, Switched it of and back on would not go unless you "tapped with a stick" took out the cartridge then the red light out on the switch.
Ya burned her up! :eek_animated:
Buy a new pump.:wink_thumbup: |
Yep, as Larry suggests, she is 'toast'. Just check to make sure you have power on the wires at the pump when you turn on the switch then replace the pump.
yes i thought s much ,thank you both
As you said Mickey under the driver console 7.5 amp,I like a good laugh but come on right under the steering rack had to get in through map locker, but guess what not toast, thanks again for all you help and advice this club is so friendly glad I'm in it although it did take six years to get involved,I sent some pics don't know where that went.
Sweet , fuse system actually worked!!
Glad you got away easy on that one Roger. Did you follow the links I gave you in your First Introduction Thread? Should work for adding those pics.:wink_thumbup: |
I did Larry first it wanted to send all my pics I sust that out, uploaded about 4 pics [ twice ] but could not add a caption,I would like to put one my thread.
Anyone know were the fuses are on a 2001 mariah z275?
| All times are GMT. The time now is 01:02 PM. |
