Thru hull Exhuast 222 Shabah
Old 02-19-2014, 11:03 PM   #1
busby1981 is currently offline
My Model: 222/Z222
My Engine: 5.7 alpha 1
Send busby1981:
Default Thru hull Exhuast 222 Shabah
Does anyone have thru hull on there 222 Shabah ? Im wonting to put it on mine I need pic of the Exhaust. I cant seem to find any pics of it. I need some of the back and engine compartment. It seems to have a double walled transom kinda different to me. Thanks Chris
  • Old 02-21-2014, 03:23 AM   #2
    Default Re: Thru hull Exhuast 222 Shabah
    Not cheap Chris.
    Do a search on Corsa or Captains Call , and you'll get a lot of info.
    Old 02-24-2014, 06:04 PM   #3
    dcgragg's Avatar
    dcgragg is currently offline
    My Year: 96
    My Model: shabah 200
    My Engine: 5.7
    Send dcgragg:
    here is a pic of mine. i did not use corsa and it does not have a solenoid to quiten the exhaust. it is loud always..... and i love it.
    Old 02-24-2014, 06:06 PM   #4
    dcgragg's Avatar
    My Year: 96
    My Engine: 5.7
    Send dcgragg:
    mine is a shabah 200
    Old 02-25-2014, 12:16 AM   #5
    My Model: 222/Z222
    Send busby1981:
    Thanks For Thw Pic. How Is The Inside Done? I Dont Know Where They Go Though The Hull At.
    Old 02-25-2014, 11:21 AM   #6
    dcgragg's Avatar
    My Year: 96
    My Engine: 5.7
    Send dcgragg:
    the way i did mine is....centered the outside hole first, used a hole saw and bored a hole through the hull. then used a sawzall and removed enough of the inside wall to get access to the exhaust manifold. the problem i ran into is that the angle from the exhaust manifold to the outside hull is such that i had to cut the flange off of the exhaust tip and align it and reweld after the proper angle was achieved. i dont have any pictures of the inside wall clearance. hope this helps.....
    Old 02-25-2014, 11:25 AM   #7
    My Model: 222/Z222
    Send busby1981:
    Yes That Helps Thanks For Your Help.
    Old 02-25-2014, 11:30 AM   #8
    dcgragg's Avatar
    My Year: 96
    My Engine: 5.7
    Send dcgragg:
    in my opinion, it is a LOT of work! but the outcome is well worth it....
    Old 03-05-2014, 12:43 AM   #9
    Ken Towers is currently offline
    Send Ken Towers:
    Hi I did my 2000 Z202 last spring and I used a kit from moore performance if you want to call me I can fill you in, the kit was 299.00 and I bought the tips with the right angel for 200.00 and 2 feet of 4 inch hose all in all I had about 6 or7 hundred in parts it is awesome!! 740-815-2890 ken
    Old 03-05-2014, 01:01 AM   #10
    Send Ken Towers:
    I wanted to put a picture on here
    but I cant get it to work if you call I can send you some
    Mariah Z222 Shabah BR 7.4L 454 MPFI V8/Silent Choice Thru Hull Exaust jsewall82 Mariah Boats For Sale & Wanted 6 06-02-2013 11:34 AM
    THRU HULL EXHAUST for a 218 Shabah JENZO Original Mariah Talk 13 09-19-2009 03:27 PM
    1999 Shabah 202 with antifouling "stuff" on hull kgoo Original Mariah Talk 3 07-02-2009 07:56 PM
    1996 Shabah Z212 Limited Edition Blue Hull sydsam05 Mariah Boats For Sale & Wanted 0 06-15-2009 12:51 AM
    2001 Shabah 250 Yellow Hull! bpfirrman Mariah Boats For Sale & Wanted 4 05-23-2008 03:07 PM
    Total Threads: 13,324
    There are 368 users
