-   -   Fuse location - 1998 214 Jubilee (http://www.mariahownersclub.com/forum/original-mariah-talk/8688-fuse-location-1998-214-jubilee.html)
Blenderbill 08-19-2013 12:26 AM
Have no power to my radio and fish finder. No problems anywhere else. I can't locate the fuse box. Is it accessible from the cabin? or somehow behind the steering wheel?
Thanks for any help!
Bill
mikeyt 08-19-2013 01:42 AM
Re: Fuse location - 1998 214 Jubilee
A quote from one of the many threads on this subject: If it is a 24' Jubilee you have to remove the inside head cover in the toilet area. If its a 22' ft it is inside behind the stereo.
Blenderbill 08-19-2013 03:19 AM
Thank you for the reply. How about a 20ft. ?
Bill
Scleepy1 06-27-2016 04:05 PM
The fuses on a 98 Jubilee 214 are behind the throttle/trim controls. $ screws and you are there.
Murdan 08-09-2016 02:02 AM
21 jubilee .After long search I did find fuse panel and replaced 2 blown fuses. However did not fix my problem does anyone know of another possible solution.
My cigarette lighter or auxiliary bottoms not working.
Scleepy1 08-09-2016 02:45 AM
There is a circuit breaker on engine. I took mine back to dealer and they fixed my short. My bilge, depth finder weren't working. That's what they said was the problem. Not for sure as I had my doubts and it took a couple hours to fix. Hope this helps.
Murdan 08-09-2016 02:34 PM
Ok I will look there tonight.
Just wondering if thereis a 12 volt converter of sort. Found a wire that was tagged under the sink where the second cigarette plug is located
