Need a replacement swim ladder suggestion...
New Mariah owner here. just bought a nice 99 shebah 202 but I need to repair a few things. most pressing, the swim ladder is missing. the bracket is there but no ladder. any suggestions? aftermarket or oem is fine. If there's a ladder that fits the bracket that would be great as I read the thread about removing the pump to gain access tto the hole with the mounting bolts lol!
Thanks and I am so happy and proud that my family now owns a Mariah!! And it's our first boat to boot!! Doesn't seem like I could have bought a better boat! |
Re: Need a replacement swim ladder suggestion...
can you post pics of the ladder area ? along with width measurements ?
I have one on my Z302 that ill be removing fairly soon. |
I will try to post some pictures I am really in need of an immediate replacement so my kids can get back in the boat. is the original ladder still available somewhere or does anyone know of an aftermarket ladder that works well I like the way the stock one seems to have slit in the slot out of the way
I'm not ready just to remove. Gotta build a swim step first
can anyone recommend a replacement swim ladder or can you still get an oem one from somewhere?
Unfortunately they are difficult to find. Try eBay, Craigslist or our own Marketplace. Knightriderz had a 2 step one for sale last year. Not sure if it sold.
I happened to run across mine while cleaning the garage! I removed it when I put on the extended swim platform. It's original, from a '99 Z212 Shabah. 3 steps with the plastic pads. It's a little dirty, but should clean up and function perfectly! It has the mounting bracket, but I'm not sure where I put the nuts and bolts. Those should be easy to replace, just make sure to use stainless steel.
Thanks again! |
If I don't hear from Indy I have found a 2 step. Am I going to want the 3 step on the 99 202? If so couldn't I drill the correct mounting holes in this instead of drilling my boat?
: New 3 Step Under Platform Boat Boarding Ladder Telescoping Stainless Steel | eBay |
| All times are GMT. The time now is 03:32 AM. |
