-   -   Fresh Water Supply (http://www.mariahownersclub.com/forum/original-mariah-talk/7868-fresh-water-supply.html)
TStroud 03-20-2013 01:25 AM
Fresh Water Supply
I purchased a 2000 Z244 Jubilee. It has a sink but I can't find where to fill the fresh water tank. It has a hose from the floor to the sink under the passenger side console but I can't seem to figure out how to put the fresh water in. I assume that there is a tank under the floor. Please help!
csterner 03-20-2013 02:13 AM
Does the hose go thru the floor or is it just laying on the floor? Not sure on your boat, but on my sink it has a hose that connects to a portable "bag" of water like this:
http://www.basspro.com/Fold-A-Carrie...ductextensions
TStroud 03-20-2013 02:21 AM
Re: Fresh Water Supply
Thanks! I'll check it out tommorrow
ShabahZ280 03-20-2013 01:44 PM
Almost all of the sinks (with the exception of the MCC cruisers) use a portable water "bag" like Csterner posted.
The easiest way to check is if it doesn't have a stainless steel fill port mounted on the outside of the hull, then it won't have a holding tank. :)
V-side-down 03-30-2013 06:57 AM
My 214 has a chrome fill port on the side, a elect pump behind the forward panel. The hose goes under the floor to the best I could see without tearing more apart a tank. I am not sure the gals. of the tank, have not checked. It seems to bee at least 5-10 by how long i have had the hose in, maybee more.
kdcox1962 05-28-2016 09:56 PM
I have a 98 jubilee 244. I also would like to know how the sink works. I have the collapsible bag like someone posted. I hooked it up but no water came out of the sink. Do I need a pump of some sort that is missing?
Jubilee Steve 07-22-2016 02:42 AM
I have a 98 jubilee as well and cannot get the water to pump to sink. How does it go from bag to faucet ?
