-   -   Engine Hatch (http://www.mariahownersclub.com/forum/original-mariah-talk/7506-engine-hatch.html)
Brad97 10-08-2012 01:37 AM
Engine Hatch
Have 1997 Z222 it only has one electric lift rod on starboard side, is this normal it lifts the hatch crooked seems like that would be hard on it over time.
ColoradoDiablo 10-08-2012 02:08 AM
Re: Engine hatch
Sorry Brad , I renamed your thread. My bad :(
Is there a spring shock on the other side? If not there should be.
Larry
ColoradoDiablo 10-08-2012 02:18 AM
re: Engine Hatch
Bama ,
you need to start a thread with your request in the proper forum. :)
You'll get better results that way. :)
That being said , Have you tried a SeaFox dealer?
Larry
Brad97 10-08-2012 01:22 PM
Re: Engine hatch
Larry
No there isn't, doesn't look like there ever has been, no screw holes on bottom of hatch or floor.
ColoradoDiablo 10-08-2012 03:44 PM
Re: Engine Hatch
If it was me Brad , I'd put one in. That would solve the issue. Make sure the hatch isn't rotted and causing it to twist.
I can't remember if the hatch is wood or fiberglass. You can do a search here on MOC and maybe find out.
Either way I'd install one.
Larry
Brad97 10-08-2012 05:15 PM
Re: Engine Hatch
Larry
Thanks Larry thats what I'll do.
kruthes1 10-08-2012 11:25 PM
Re: Engine Hatch
Mine has a hydro. shock on the opposite side from the electric ram but it still goes up slightly tilted ???
