-   -   HELP 1994 z220 Talari Engine wire picture (http://www.mariahownersclub.com/forum/original-mariah-talk/7377-help-1994-z220-talari-engine-wire-picture.html)
cp55 09-02-2012 12:43 PM
:confused:HELP PLEASE. Can anyone take a picture of where the wire from the outdrive trim sensor coming into the engine compartment plugs into> also where the wires go from the small drive resovoir plugs into. HELP PLEASE>>>>>>>>>> I have a good mechanic just not a good wire marker.
I need your help. As always THANKS and hope i can help someone else.
PS I have a 350 mag with alhpa outdrive.
E-Mail [email protected] and ill check TTTTTTTTTHHHHHHAnks
Hudson River Steve 09-02-2012 01:47 PM
Re: HELP 1994 z220 Talari Engine wire picture
1 Attachment(s)
The trim sensor wires come from the transom to the engine harness. They are both black and have bullet connectors on the end of them.
The gear lube monitor has two wires. On my 7.4 MPI one wire is black and goes to a ground, the other wire is tan with a white stripe and goes to the fuel injection computer. Both of these wires also have bullet connectors on them. I think all Mercs are the same.
I don't have pics at the moment but attached are some excerpts from my Merc manuals.
Good luck.
cp55 09-02-2012 07:04 PM
Hudson River Steve,
Thanks for the help I will go check it out and let everyone know how it work. Have a great day and truly appreciate your time getting back with me. Curt
cp55 09-02-2012 10:48 PM
Im not quite there yet the wiring is different on the EFI 7.4 mine is the 5.7 mag. Does anyone have a pic or info on that again THANKS for your help. Curt
