96 Shabah SE - cut the dash ?
Howdy all, my first "official" post outside the intro thread. 96 Shabah 180 SE - did not come with a depth finder. I'd like to add one and I am wondering if these are made like cars where there's a "cut out" behind the dash and I just need to cut through the face or if I would be shooting in the dark.
Second, opinions on cutting a stock dash of a boat that's obviously rare, or just get an aftermarket job and find a safe place to mount it. (out of the way like) :yes_grin: |
Re: 96 Shabah SE - cut the dash ?
I did just that with my '96 180. I used a proper sized hole saw & placed the depth finder just to the right of the fuel gauge. There is room there but there are no cut-outs so i just made sure there was no wiring routed where i was mounting the gauge.
Thanks Mikey!
Any other pictures of the dash? I'd like to see how it looks all together and where exactly you placed it. Thanks again! |
Did the same as Mikey with a hole saw.
Not a bad job, just be very careful as you will not be able to replace that dashboard. |
Do you fish at all?
Install a fishfinder if you are nervous about cutting. Just a thought. Larry |
I think I will probably go the route of the fisfinder. I really don't want to modify the dash.
On a side note, we had her out this weekend and the water temperature gauge was not working. Anyone know if it's possible to find replacement gauges that match original or will I need to replace the whole set? Also, if it's not the gauge, where is the sending unit located on the 4.3 liter engine. I looked up on the top/front of the motor and couldn't find anything on or around the manifold or water passages? Thanks guys |
Should be right on the side of the thermostat housing. There is another in the block , but it is the switch for the alarm system in case of overheat(If yours has the alarm option).
Just wondering , did you check and make sure all the fuses are good. Was the gauge pegged over on the hot side or down on the cold side? Larry |
And if the thermostat is located at the front/top of the block on the intake manifold (as it is on every other chevy motor I have worked on) it is missing, there are a couple of "plugs" there though, so that might be where it should be. Thanks for the quick response! |
| All times are GMT. The time now is 07:30 PM. |
