Re: Purchased a bunch for goodies for my Shabah 222
Sounds like you are running on low voltage. You need to check your alternator to see if it's charging, and have your batteries tested as well. If the alternator is charging properly, you SHOULDN'T have the RPM issues, even with a dead battery..... but DC voltage will do funny things (especially when bad grounds are involved)
Thanks. |
Since I dont know what your wiring system looks like it just sounds suspicious. I agree with DCB_MINDED, you should have your batteries and ALT checked out. If you have access to a clamp meter you can check the ALT to see what its pushing (AMPS). |
So has the tower went on yet? I am about to install a tower on my 98' 222, so I am looking for lessons learned.
| All times are GMT. The time now is 11:59 AM. |
