-   -   starting problems (http://www.mariahownersclub.com/forum/original-mariah-talk/6666-starting-problems.html)
sergio1209 04-13-2012 02:37 AM
starting problems
i have a 1996 mariah shabha it was runing good last october and i try starting it today and it wont start the engine turns but it wont start i dont know if its electrical or the carb wut can i do to knoe wut the problem is:(
sergio1209 04-13-2012 02:39 AM
Re: starting problems
i try to look for the wiring manual on line so i can chek the distrbutor wiring couse i notice there was to wires loose coming out of it
mikeyt 04-13-2012 03:09 AM
The first thing i would suggest you check is the Kill Switch to make sure it is in the Run position.
sergio1209 04-13-2012 03:23 AM
i did and the kill switch was on run
mikeyt 04-13-2012 05:59 PM
Here's a link to a diagnostic procedure from Sterndrives.com
