-   -   Captains Call Not "opening" ? (http://www.mariahownersclub.com/forum/original-mariah-talk/6502-captains-call-not-opening.html)
Mariah on the bay 02-18-2012 12:35 AM
I have a 97 z275 Shabbah it has the 7.4 it has the oem Captains Call and the last time I was out in the fall the exhaust just got quiet.. Any ideas just trying to figure out what I am gonna be looking at in the spring
Zackattack 02-18-2012 03:35 PM
Re: Captains Call Not "opening" ?
There are a couple of red button type circuit breakers in the engine compartment for mine. Try those first.
Sounds like they just lost the power to activate them. There are also some quick connect fittings on them you should check for good connections.
Should be something electrical, you can check the voltage they are getting by disconnecting that quick fitting at the actuator to verify good power.
