Swabbing the deck
I have the non-slip fiberglass flooring in my Shabah. I find it hard to clean, the non-slip grooves are fairly deep. Soap and water work ok if you use a brush and scrub the daylight out of it. Even a power washer doesn't really do the trick.
Does anyone else have this type deck and what works best for you? Is there a cleaning product that works well that I haven't tried? I would hate to use bleach :( Thanks everyone |
Re: Swabbing the deck
My father in law uses Star Brite "Sea Safe" hull cleaner on his non-slip floor. Just leave it on for 1-2 mins then hose or powerwash it down. Seems to work quite well on the flooring as well as the hull.
| All times are GMT. The time now is 04:16 PM. |
