-   -   Stupid Question: Starting my Z272 Barchetta (http://www.mariahownersclub.com/forum/original-mariah-talk/6058-stupid-question-starting-my-z272-barchetta.html)
JoeDoyle 08-17-2011 11:17 PM
Hey guys,
First time boat owner and it seems like my boat takes too many key cranks to start. Am I giving it too much gas? Too little? The boat is a 95 z272 with the throttle separate from the shifter. I have been pushing the throttle up about 2 inches when trying to start, and going back and forth sometimes. Do I need to be priming the throttle more? I just dont want to flood it. Any info is appreciated! Thanks and sorry for the dumb question.
Joe
mikeyt 08-18-2011 12:29 AM
Re: Stupid Question: Starting my Z272 Barchetta
Not really a 'dumb' question... my particular motor requires that i pump the throttle fully twice then set it at 1/4 throttle on a cold start and just set it at a 1/4 throttle for a warm start.
darkcalling 08-18-2011 12:43 AM
Mine is the same as Mikeys on my 502 mpi it needs a couple pumps when cold so she fires right up and one to about 1/4 when warmed up.
DFZ272 08-18-2011 01:16 AM
Same here, 2 pumps 1/4 open. 7.4 Carb model
Happy Boating
Dan
rajjneef 08-18-2011 02:18 AM
EFI/MPI or carbed? I used to pump carbed engines a good bit depending on the condition of it all. Most people dont remember the old days of carbed cars and how they had to pump them. Darkcalling... No reason for you to pump a MPI.
mikeyt 08-18-2011 02:47 AM
OP has a 1995 Barchetta so i'm presuming it's a carbed version.
darkcalling 08-18-2011 04:20 AM
Lol tell my 502 that, it likes a little pumping for some reason never thought an injected engine would but it starts easier if I give it a couple, easier on the starter
Dredd 08-18-2011 01:53 PM
Originally Posted by darkcalling (Post 32065)
Lol tell my 502 that it likes a little pumping for some reason never thought an injected engine would but it starts easier if I give it a couple easier on the starter
We had a FI car that liked for the pedal to be pushed clear to the floor before starting too. I don't know why either, but it definitely worked.
As for the OP, I'd echo the others' advice. Pump it first to get some gas in the carb.
Jgos929 08-18-2011 04:12 PM
I noticed I have to give mine a little gas on a cold start but after its warmed up I dont need to.
rajjneef 08-18-2011 04:44 PM
Strange on the EFI/MPI needing pumped for sure as it is computer controlled and not manually controlled. I have never pumped my EFI but it will take 3-4 seconds to hit if it hasnt been run in a few weeks. If its been run in a week it will hit almost instantly every time.
