-   -   Fuse Panel (http://www.mariahownersclub.com/forum/original-mariah-talk/5723-fuse-panel.html)
ezgoin45 06-26-2011 10:59 PM
Fuse Panel
Okay I admit I can't find it. I'm Ezgoin 45's wife. I have been trying to find the fuse panel on our 2000 Mariah 214 jubilee. Any suggestions? I have hunted everywhere. Hubby is not home right now and I blew the fuse for the axillary cigarette light blowing up a float. I want to get it fixed before he comes home :confused: (my red face)
ShabahZ280 06-27-2011 02:00 PM
Re: Fuse Panel
Usually they're hidden under the drivers console. There may also be a black panel with white push button switches mounted around the helm somewhere if you've got a newer model Z series. It's the circuit breaker system, if the fuse is blown, the white portion will pop out and you just need to push it back in. Good luck with it, and let us know if you found it, and where it was located!
ezgoin45 06-27-2011 10:34 PM
Re: Fuse Panel
Thank you I'll go look tonight. I don't think there is anywhere I haven't looked. It's got to be somewhere. We have a 214 jubilee deck boat. I'm not sure if this makes a difference. Thank you again for your help. Ezgoin45's wife
CChrun636 07-04-2019 02:57 PM
Re: Fuse Panel
I have z280 also and my bilge pump quit working .. I'm currently searching for a possible blown fuse also
Hudson River Steve 07-05-2019 11:08 AM
Re: Fuse Panel
Which pump stopped working? The mid ship pump under the cabin stairs or the pump in the engine bay? Have you tested using a voltmeter? I have never had a fuse blow but have had to repair the wiring due to corrosion multiple times.
Unknownmariah 07-24-2019 10:10 PM
Re: Fuse Panel
What amp fuse are recommended by Mariah? I have a feeling I have the wrong ones...
mmendenhall 07-30-2019 03:02 PM
Re: Fuse Panel
I had a similar issue with my bilge too. Go take a look at my thread for a picture of what you're looking for under the dash.
Yes, its only a 202 Shabah but maybe it will help you.
