-   -   Tower Install (http://www.mariahownersclub.com/forum/original-mariah-talk/5532-tower-install.html)
jnd_v 05-31-2011 06:28 PM
Tower Install
I have a 1996 Z220 Talari, wanting to add a tower, side mount. how do I go about removeing the interior panels? This will need to be done in order to mount the harware for the tower.
Hyperryd 05-31-2011 11:03 PM
Re: Tower Install
If you are talking about the inner fiberglass panels, you need to remove the upper padded trim panel which just lifts off and then remove the long carpeted panel,at the bottom, that is held on with screws that are just hidden in the carpet pile. You will then see the upper and lower screws that hold the fiberglass panel in. Remove these and you are in business. Make sure you post some pics of your install, before, during and after. :wink_thumbup:
jnd_v 05-31-2011 11:05 PM
Re: Tower Install
Thanks, I will have to look into it a bit better, I just took ownership this last week!
knightriderz 06-10-2011 08:49 PM
Re: Tower Install
check out this how to:
http://www.mariahownersclub.com/foru...20-talari.html
be glad to try to answer any questions!!
Good luck--also a few pix of the finished project in the gallery.
Currently working on new stereo w/ tower speakers, swim platform extension, and M120 sporttabs!!!
Hope to finish tomorrow and be on the water Sunday afternoon!!!
Boat Safe,
Knightriderz
