-   -   Z308 Parts - Dimensions (http://www.mariahownersclub.com/forum/original-mariah-talk/544-z308-parts-dimensions.html)
topgunwolf 12-14-2007 08:09 AM
Hi@all:yes_grin:
Can anyone give me the dimension of the following parts on a Z308::confused:
Table inside and bolsters to build the bed inside, also form the big bolster in cockpit which can be placed on the table oustside.
Thanx @ all
Greetings from Austria
Wolfgang:wink_thumbup:
S.L.P. 12-14-2007 02:00 PM
Z308 interior
1 Attachment(s)
Wolfgang,
I have a 2000 Z260MCC that has very similar, if not identical, interior. Look at the Z308 gallery in year 2000. My table is an odd trapozoid shape with radiused corners. In 2000, the cabinetry are all gloss cherry laminate, as is the table. Is your Z308 the same? Obviously, the Z260 cockpit is much smaller than the Z308.
I have all the cushions that make up the forward v-berth. They are usually stowed in the aft cabin when not in use. If they are in place, then the table is set up in the cockpit. Most often, I leave them home. Are these the bolsters you refer to?
The attached photo of the interior shows the table and the cushions for the v-berth. Please excuse the clutter, as I am a slob.
steve
topgunwolf 12-16-2007 02:05 AM
Hi S.L.P.:)
Yes it looks to be the same.:wink_thumbup:
Can you give me the details so that we can rebuild ours?
Thx
Greetings
Wolfgang:D
S.L.P. 12-16-2007 04:30 AM
4 Attachment(s)
Wolfgang,
Attached are some photos of the table. I have placed a tape measure in the photos. The table appears to be made of a wood product with a cherry laminate on it. Formica makes a laminate similar, named Cherry Birch #7484-58, in a matte finish. Wilson Art makes a similar laminate called Wild Cherry #7054-60, also a matte finish. The table top is trimmed with what appears to be a teak trim/molding.
I am trying to locate the laminate in a gloss finish. I am trying to make a table a little bit smaller to fit our needs. So far the gloss finish eludes me.
Let me know if the photos are adequate. Additional photos or dimensions can be sent to you.
Tomorrow, photos of the cushions. They need to be removed from the boat, under 18inches of snow.
steve
topgunwolf 12-16-2007 09:49 AM
Hi
Great, thank you.:)
Are the dimensions in inch or centimeter?:confused:
Yes please, if possible to remove the snow;)
The last one thing what is miising on our boat is the dimension of the cushion from the table outside to build a bed too.
A big THANK YOU for your help!
:wink_thumbup:
Greetings from Austria (25cm Snow :eek_animated:)
Wolfgang
S.L.P. 12-16-2007 12:31 PM
Topgunwolf,
I used both metric and feet/inch tape measures. Sorry , it was all I had here.
Photos of the cushions will be posted soon. I will try to do better with the lighting and focus. ck back in an hour.
steve
S.L.P. 12-16-2007 01:00 PM
5 Attachment(s)
Topgunwolf,
more photos of the cushions that make the v-berth.
steve
topgunwolf 12-16-2007 01:05 PM
:)Thank you very much!!!
Best regards
Wolfgang:D
S.L.P. 12-16-2007 01:06 PM
Topgunwolf,
contact me if you need any more info.
steve
topgunwolf 12-16-2007 01:10 PM
The last one thing what is missing on our boat is the dimension of the cushion from the table outside in the cockpit to build a bed too.
