-   -   Battery Disconnect Switch (http://www.mariahownersclub.com/forum/original-mariah-talk/4731-battery-disconnect-switch.html)
shabah96 08-17-2010 03:24 AM
One of many questions to come. Does my 1996 Mariah Shabah 200 Limited have a battery disconnect switch? Reading the 97-02 manual it said that every Mariah came with one but I don't see one in my boat and the manual for 00-96 is missing pages 4-7 where it talks about the battery. Also the 97-02 manual does not mention where the switch is. Does anyone know this?
thank you
robetello 08-17-2010 03:48 AM
Re: Battery Disconnect Switch
Hi, I am new to this but our 97 Z209 Talari has a battery disconnect switch. It is located behind the drivers side rear seat. My battery nkind of hides it but we found it a couple weeks ago. It is kind of reassuring to know that nothing is left on when you use this disconnect switch.
I am interested in your 97-02 manual. Is it in electronic version? If so will you send me a copy?
We just recently purchased our Mariah and are searching for information on it.
Bob
shabah96 08-17-2010 04:00 AM
I will have to check when I go down to the lake this weekend.
The manual is available on this website under Original Manuals.
thank you
robetello 08-17-2010 04:04 AM
Thnaks for the information regarding the owners manual. When I try to access the manual it says that I have limited access, Do you have to be a contributer to gain access?
Bob
shabah96 08-17-2010 04:13 AM
I forget the exact way it worked but you either contribute some material or if you don't have any it's like $20 and then you gain access to all the material.
robetello 08-17-2010 04:15 AM
Thanks Les, I appreciate the information!
