Z302 Cushions
Hey Guys,
2nd time Mariah owner, 1st time poster. Let me thank you so much for the great website. Keep up the good work! I recently bought a 1999 Z302 and have an extra cushion that I cannot figure out where it goes. I have the bow filler cushions, and the cuddy filler cushions, but then I have one extra cushion. It measures roughly 4 1/2' X 2 1/2' and has a small ~5" strap with a snap on the end of it on both short ends. My inital thought was that it went on top of the cuddy when the center window was opened, but it doesn't seem to fit. The only other thought I had was that it once fit on top of a cooler? Any 302 owners know what I'm talking about and where it goes? Thanks in advance. Nick |
Re: Z302 Cushions
Check to see if it fits the rear wrap-around seat to make a large sun-pad. It may be supported by a table type post.
Re: Z302 Cushions
I will give it a try. If that is where it goes, wouldn't there be some sort of "post hole" on the underside of it? It doesn't seem to have anything like that. Thanks again.
Re: Z302 Cushions
If it helps, here is a picture from the '01 brochure showing the Z302 rear filler that z275st was referring to:
http://i66.photobucket.com/albums/h2...RearFiller.jpg WetWilly |
Re: Z302 Cushions
That's exactly where it goes. It must snap onto the table that sits back there and use the two short poles under. Thanks guys. I really appreciate it.
Re: Z302 Cushions
Is there actually a table that can go there also, or are those short poles exclusively for that cushion? I just have the poles and wasn't sure what was suppose to go there.
Re: Z302 Cushions
I have a rectangular shaped table that goes there with a drop in it (I'm assuming for the single gas burner that came with the boat?) I think if I put the table on the short legs and place the cushion/snaps onto the table I'll get what is shown in the above picture. I know there aren't circular holes or guides on the bottom of that cushion so I'm thinkin' that it wouldn't sit on the legs by itself.
Re: Z302 Cushions
Wow. We have had our z302 for three years and never did no where the extra cushion went. Thank you now I do.
| All times are GMT. The time now is 07:30 PM. |
