-   -   1993 350 mag makes growling noise (http://www.mariahownersclub.com/forum/original-mariah-talk/4304-1993-350-mag-makes-growling-noise.html)
benelli5150 06-22-2010 04:14 AM
I just started my 93 shabah 2110 for the first time in two years. I changed all fluids hooked her up yo water she fired up right away running smooth water temp and oil pressure were good and then a growling sound started coming from engine. There isn't any rod knock that is typical of a spun bearing. Any thoughts to how bleak my situation or any thoughts of encouragement would be helpful.
tmonson 06-22-2010 01:05 PM
Re: 1993 350 mag makes growling noise
Remove the belt and start it to eliminate alternator, water pump etc. Could be a bearing in one of those. Don't run it too long. If it's a Bravo it could be the raw water pump.
benelli5150 06-22-2010 02:56 PM
I removed all belts sound is still there. There was alot of rust debri that blew out of the exhaust is there a possibility some debri blew into impeller or outdrive that would cause the noise and the outdrive is a alpha 1
tmonson 06-22-2010 03:19 PM
I wouldn't think rust or debris would do that. You said that temps are normal, this should indicate that the impeller is in working order. Could possibly be a gimble bearing going bad. Given the boat hasn't been run for two years I would suspect a bearing of some sort. Grease the gimble and see if you notice a change in sound.
benelli5150 06-22-2010 03:53 PM
Thank you for the info it's makeing me feel a little better
Z 202 06-22-2010 04:47 PM
If the growing sound changes as you steer the drive back and forth underway it's very likely your gimbal.
indykoch 06-23-2010 03:30 AM
I agree, probably gimbal bearing and/or U-joints.
benelli5150 06-23-2010 03:53 AM
Thanks everyone for the info found out today by a mechanic that it is definately the gimbal going to have it replaced got a quote for 200.00 to fix parts included. That sounds like a fair deal to me
indykoch 06-23-2010 05:07 AM
That's actually quite cheap!! Since he'll need to remove the drive anyway, you may want to have the u-joints and bellows replaced at the same time. It'll cost a little more, but save you in the long run since you won't need to pay the labor of removing the drive 2 or 3 times over a couple years.
benelli5150 06-23-2010 11:38 AM
Definately going to replace all the boat has less than100 hrs on her she just sat exposed to the elements for several years so I'll gladly spend the extra money now.
