1999 Jubilee Alarm Buzzer Problem
Has anyone else had a problem with their alarm buzzer??? We have checked everything and can't find anything wrong except the buzzer stays on most of the time. Any suggestions would really be appreciated ! Thanks:confused:
Re: 1999 Jubilee Alarm Buzzer Problem
Check the level in the drive oil reserve tank. If not low, then be specific as to what you have checked rather than the blanket "checked everything".
The members here can help but we need good preliminary info to allow us to give good advice on what to check. :wink_thumbup: |
Great we will try that
Double on that. Those alarms usually sound for low drive oil, over heat, and low oil pressure. Check you gauges while running, if oil and temp look good its the drive oil OR one of the three sensors that detect any of those are misreading.
That corrected the problem!!! Thank you again
Sharon |
It was low drive oil...Thanks for the help
Good to hear. :wink_thumbup:
We like to hear feedback when we have given good information and that it solved the problem.:yes_grin: |
| All times are GMT. The time now is 11:40 AM. |
