-   -   Potential New Owner of a 1994 Z212 (http://www.mariahownersclub.com/forum/original-mariah-talk/3891-potential-new-owner-1994-z212.html)
BenScott 04-12-2010 01:48 PM
Hello everyone,
I'm currently looking into buying a 1994 Shabah Z212. One of the local boat shops took ownership of the boat after the owner failed to pay his $2600+ repair bill. The boat looks like it's been sitting outside without a cover for a while now and needs a lot of cleanup and TLC but on the plus side all of the $2600 was put into the engine so she should be running great. I should be able to take it home with me for under $6K and I'm thinking it would be a great first boat.
Also, the NADA site lists the weight at 2700 lbs. Is this correct? I have a 2001 4Runner which should be fine for towing it the short distance to the lake but I just want to be sure.
Anyway, if everything works out I might be a happy Mariah owner soon!
Cheers!
TXMariahDLP 04-13-2010 01:23 AM
Re: Potential New Owner of a 1994 Z212
Hello and welcome,
The Shabah Z212 weight is listed at 2700lbs. The fuel tank holds 40gal.
L.O.A......21'2"
Max H.P. - Prop.......250-V8
Performance depending on what engine it has are as follows:
4.3 L.......43-48
4.3 LX......45-50
5.7 L .......52-56
350 Mag...55-60
As for weather your 4Runner will tow it or not, I'm not sure. I would call and ask your local dealer. Good luck.
WetWilly 04-14-2010 12:28 AM
Ahoy Ben and welcome to the club!
It's listed that the 2001 Toyota 4Runner SR5 4X4 has a max tow capacity of 5000lbs so you should be fine with your Z212.
BenScott 04-14-2010 01:08 AM
Thanks for the info guys. My research also leads me to believe that I should be just fine towing it with my 4Runner... I'll post some pics if I do indeed wind up buying the Mariah.
WetWilly 04-14-2010 10:05 AM
Good luck Ben and hope to see you back soon as a new Mariah owner :wink_thumbup:
