| Welcome to the The Mariah Owners Club. |
Jittery Fuel Gage
02-05-2008, 02:57 PM
#11
My Model: 1993 Diablo 180
Question,
In the original post you said to install a 60,000 uF capacitor, but in the pdf file it says 68,000 uF?
Thanks for the photos as well. That helped me out a lot in understanding what you did to add it. When I originally read this back in October I thought you meant you had to put it at the fuel sender unit under the rear carpet.
But since its behind the dash, looks very simple enough to accomplish. Looks like in June I will do this.
  Thanks !
~ Ryan
Owner of the 3.0L Powerhouse!
02-05-2008, 10:40 PM
#12
Paul F is currently offline
Don't know about the rest of you, but I found out the hard way that you can go a long way with the fuel gauge resting on "E".
And the gauge stays pretty steady once you get to "E".
02-09-2008, 11:44 PM
#13
sledge437 is currently offline
Thanks from me as well. What a great solution!
02-13-2008, 06:23 AM
#14
rjobe is currently offline
Status: Silver Contributor
Originally Posted by 180diablo
Question,
  Thanks !
180 Diablo,
68,000uF is the corrrect and a readily available capacitor value. It doesn't need to be precise. The higher the value the longer the time constant and dampening of the gauge.
Regards,
Randy
Randy
1995 Z202 Shabah, 350 Mag / Alpha 1
Springfield, OH (kept @ Indian Lake, OH)
02-13-2008, 02:31 PM
#15
Originally Posted by rjobe
180 Diablo,
Regards,
Randy
Thanks Randy. That is what I suspected was the case, but I noticed the difference and I had to ask. I have no idea what kind of a difference from 60,000 to 68,000 makes.
~ Ryan
05-29-2008, 06:49 PM
#16
Gary Black is currently offline
My Model: 1999 182 Bowrider, Mercruiser 3.0 litre, Alpha one leg
Fuel Guage
Hello Guys,
In case anyone is interested, there are today (29th May) a couple of Mariah fuel guages and a very nice speedo for sale on the US Ebay site.
Cheers,
Gary
06-02-2008, 02:06 PM
#17
My Model: Z250 Shabah LE
My Engine: 7.4L MPI Bravo I
Randy, just wanted to say thanks, fuel gauge is much more stable after this modification. I'd recommend it to anyone!
7.4L MPI, Bravo I
06-03-2008, 04:16 AM
#18
Glad it worked for you. It gets more stable as you go from full to empty because the fuel sensor resistance goes up.
Randy
06-16-2008, 06:33 AM
#19
azboatman is currently offline
My Model: 1999 Shabah 182, Mercruiser 4.3L, Alpha One
Hi all,
Anyone have problems with their fuel gage being jittery as the fuel sloshes in the tank? I did. The fuel sender unit is a simple resistance device that varies between ~10 ohms (full) to ~250 ohms (empty). I placed a 60,000 uF capacitor between the sender input and ground at the fuel gage and it's now nearly rock solid. It is so much more appealing and the real fuel level so much easier to read.
I have a huge issue with my fuel gage jumping. Here you say to use a 60,000 uF capacitor and on your attachment you say to use a 68,000 uF. I have 99 182 shabah 4.3L....does it matter which I use? This sounds like a great fix.
06-16-2008, 12:50 PM
#20
You can use a 68,000 uf capacitor, that's what I used.
Scroll up to Randy's post from 2/13/08, he answers the same question from 180diablo.
7.4L MPI, Bravo I
Total Members: 6,466
Total Threads: 5,950
There are 37 users
