MikeyT the smart tab expert - question
Old 03-12-2010, 06:19 PM   #21
Paul F's Avatar
Paul F is currently offline
Gallery Images: 4
Send Paul F:
Default Re: MikeyT the smart tab expert - question
I still haven't gotten a commission check from John at Nauticus.
I know we've sold a lot of tabs for him.
  • Old 03-12-2010, 08:40 PM   #22
    You have to give him your Swiss bank account number like i did.
    Old 03-14-2010, 09:15 PM   #23
    depman160's Avatar
    depman160 is currently offline
    My Model: 2000Z
    My Engine: 5.0L Merc Alpha 1
    Send depman160:
    Well, ya got one on each side of the boat rather than just one in the middle so you have more surface area lifting the stern evenly. The Smart tabs actually move up & down slightly (thru the actuators) depending on the load presented to them so they can in effect 'self adjust' to the conditions such as low speed wandering, hauling tubers/boarders or simply high speed cruising. You can set the mid point of the movement by choosing one of the 5 pivot holes when you mount them, although most applications will be in the 2-3-4 position, which allows you to adjust them to your particular boat. I also recall someone mentioning that they set one tab in one position and the other in a different position to help correct a lean while under way. And last, when first setting out on a run you shouldn't need to trim your drive in as much as you likely already do because the tabs help lift the stern & get you onto plane much faster.
    Thanks for the explanation...not sure I will invest in them, but they sound like a useful tool!
    If only it could be summer all year long!
    Old 03-22-2010, 11:23 PM   #24
    ebb8827's Avatar
    ebb8827 is currently offline
    My Model: 2000 182 Shabah, 4.3l Alpha
    Send ebb8827:
    Default Smart tabs and dry storage
    Hi,
    does somebody have experience with smart tabs an dry storage? Is the movement of the actuator enough to level the tabs parallel to the hull or will the forklift damage the flab? I saw the PR500 device at the webside but I will not be able to use it when the baot is in the water. I have a 182 shabah like Azboatman and the upper tab mounting point will be under the swim platform.
    Here the link to Azboatman picture in the galery.
    http://www.mariahownersclub.com/gall...php?n=1904&w=o
    Here a picture from the dry storage
    Regrads
    Peter
    __________________________________________________ _______
    Wer Rechtschreibfehler findet, der kann sie behalten
    Old 03-23-2010, 01:33 AM   #25
    If i remember my install correctly the mounting plate comes right to the bottom edge of the hull so it wont be a problem and there should be enough movement in the actuators to prevent any damage. For safety sake though, you could pull the pin on each so that they are loose but it means you will have to get into the water to put the pins back in. And as long as they dont slide the boat off the forks you should be okay.
    Old 03-23-2010, 11:47 AM   #26
    ebb8827's Avatar
    Send ebb8827:
    Thanks Mikey,
    I think I wil order some smart tabs
    Regrads
    Peter
    Old 03-23-2010, 12:03 PM   #27
    Phlorida is currently offline
    My Model: 250 Sundancer
    My Engine: 5.7L Bravo II
    Send Phlorida:
    I have the Smart Tabs on my SX-18 that I am removing in favor of hydraulic tabs because i have my boat at a place that uses a forklift. The tabs are pushed up by the arms of the lift but it sure looks like it is only a matter of time before they snap under load. The forklift arms are not smooth, they are covered in carpet. Removing and reinstalling the pin at every launch wouldn't be a very good option for me. My thoughts......
    Old 03-23-2010, 04:35 PM   #28
    I agree that if you have to use a forklift to launch the boat more than 1 or 2x per season the remove & reinstall the pins option would be a pain in the a$$ (and the water damm cold for those of us who wait for the ice to melt). My biggest worry would be that the forklift operator wouldn't be particularly careful in making sure that his forks completely clear the tabs as the boat floats off the forks. I think that as long as he (or she) is careful, it can be done safely.
    Old 03-23-2010, 09:14 PM   #29
    Send Phlorida:
    You make a great point that I hadn't considered. I live in Florida and boat in brackish water rivers so the boat gets put away every evening or 20-30 times a year. If I only put it down to start and end of the season I would be inclined to stay with the Smart Tabs at less than 20% of the cost of what I am considering.
    The part that scares me with the forklift is when it is being picked up, not down. The Smart Tabs are angled down from the lowest part of the transom. When the forklift picks it up the tab itself must ride down the forklift arms a couple of inches for it to rise up above the hull. If the tab catches the fabric you can just about guarantee that something on the Smart Tab is going to give. I paid around $100 for the Nauticus tabs and I am probably going to end up paying over $500 for the hydraulic tabls with labor which would buy a lot of Nauticus parts.
    An interesting note - the marina that my boat is currently at had me sign a waiver when they noticed that I had installed the Smart Tabs. The marina that I am moving the boat to won't even pick the boat up once with them installed.
    Old 05-03-2017, 05:05 PM   #30
    whitehawk123 is currently offline
    My Model: barchetta
    My Engine: 182
    Send whitehawk123:
    New owner. Boat leans to port when getting to plane.. any suggestions??
    Smart Tabs indykoch Original Mariah Talk 327 04-05-2022 12:09 AM
    Smart Tabs karmann Original Mariah Talk 13 07-22-2009 06:21 PM
    Smart Tab Help stereoman405 Original Mariah Talk 3 04-21-2009 12:23 AM
    smart tabs dmg5606 Original Mariah Talk 3 04-06-2009 03:48 AM
    Congrats to MikeyT!! 180diablo Chit Chat/Off-Topic 5 06-04-2008 12:13 AM
    Total Members: 18,994
    Total Threads: 13,325
    There are 373 users
