-   -   seats (http://www.mariahownersclub.com/forum/original-mariah-talk/3749-seats.html)
hspencer 03-01-2010 02:27 PM
seats
hello all i am a new boat and Mariah 220 Talaria owner. my boat is in great shape and i have put a new motor in it. my question is the driver and passenger seats are a great looking fiberglass seat but they are weak and will not support the weight of someone leaning on them. any suggestions on replacement seats or how to repair mine?
WetWilly 03-02-2010 06:02 AM
Re: seats
Hi hspencer and welcome to the forum!
We have had other members with a similar issue but as of yet, I don't believe we've had any solution updates. Here is one of the first threads about the seats and some suggestions (click here), hope it helps point you in the right direction.
As for replacements, you can try to source later model Mariah seats or you can go with any similar aftermarket seat designed for pedestal mounting as they should all have a fairly standard bolt pattern.
If you find a solution, we would be most appreciative if you would post your results.
Thank you and good luck,
hspencer 03-02-2010 01:33 PM
Re: seats
Thank you very much! i will post any information i find. Thanks again!
