-   -   Looking for my fuel line on a 94 shabah (http://www.mariahownersclub.com/forum/original-mariah-talk/3622-looking-my-fuel-line-94-shabah.html)
Jbetschart 01-11-2010 05:06 PM
I am installing a fuel flow indicator and want to make sure I have the correct line before I cut. Does anyone have a diagram or image of the fuel line and where it sits on the mercriser 350.
warner0308 01-12-2010 02:43 AM
Re: Looking for my fuel line on a 94 shabah
you should have only one fuel line going to the carb. i dont know where you going to splice it but it should go from carb to fuel pump and fuel pump to tank. they probally want the meter after the fuel pump.
Jbetschart 01-12-2010 04:35 AM
will I need to take the carb cover off to see the fuel line. And yes they recomend that I splice after the fuel filter.
I'll look and see if once I take the cover off it becmoes obvious.
warner0308 01-12-2010 09:25 PM
yes it will be a 3/8 rubber hose or a metall one. on my 454 there was a rubber hose to the fuel pump (lower left side) and a metal line from the fuel pump to the left side of carb.
Rdrdon 01-27-2010 08:36 PM
Mercruiser v8 350 2bbl fuel line to carb 32-8612471 : eBay Motors (item 400024122851 end time Feb-07-10 07:16:22 PST)
MAJIC 01-28-2010 01:31 PM
Shouldn't have to touch the carb to get to the fuel line post pump and filter. There is probably an internal filter to the carb (I'm not sure about that), but you'd have to put the flow indicator on before that as once the gas enters the carb, there's really nothing to attach the indicator to.
Of course I'm saying this without having seen the device...
Jbetschart 01-28-2010 02:36 PM
I found it. What threw me off was I was looking for a 3/8 hose and it turned out to be a metal hose. Once I found that I replaced the hose with a 3/8 and install the sensor after the fuel filter just like it recommends.
jgreen 01-28-2010 04:19 PM
Hi, I've been thinking about getting one of these for my Talari, let me know how you like it. By the way, what gauge did you get?
Jbetschart 01-28-2010 05:33 PM
The Faria Fuel Flow Gauge
jgreen 01-28-2010 07:43 PM
Thanks, I'll check into it.
