tech questions
I just bought a 2001 jubalee and have some questions:
where is the cg front to back? when the battery switch is off which battery runs the bilge pump? is there a fuse for the trim motor? mine just quit mid tilt. ed |
Re: tech questions
Hi Ed,
If you have a manual bilge pump, power shopuld go off when the battery switch is off, if you have an auto pump, there should be a separate wire to the battery for this function when the battery is switched off. Seeing how there are so many ways to wire up the accessories, I would verify the hookup myself by tracing the wiring back. Quote:
WetWilly |
| All times are GMT. The time now is 05:53 PM. |
