-   -   Borken Speedo (http://www.mariahownersclub.com/forum/original-mariah-talk/3374-borken-speedo.html)
cometb 09-28-2009 01:43 PM
Borken Speedo
I have a 1996 Shab. After using the boat yesterday and noticing that the speedometer wasn't working, I checked the cable out when I took it out of the water. The "hollow" tube that connects tot he device that goes into the water was disconnected. There appers to be a fitting missing so I cannot re-connect. Does anyone have any ideas on how to fix? thanks.
Jimh23 09-28-2009 02:36 PM
Re: Borken Speedo
By the 'device in the water' do you mean the outdrive or the sender which is attached to the boat?
cometb 09-28-2009 03:45 PM
Re: Borken Speedo
The plastic sender unit. The "tube" seems to have disconnected from the top of it. thanks for your help
WetWilly 09-29-2009 08:35 AM
Re: Borken Speedo
Hi cometb,
Take a look at this thread (click here), in post #12, there are several pictures of a Bravo outdrive's speedometer tube routing (the Alpha Gen II is similar), are you talking about the little plastic piece circled in green in the second picture?
cometb 09-29-2009 01:30 PM
Re: Borken Speedo
Yes but it goes to a separately mounted plastic device that has a "rod" that goes into the water (as opposed to the outdrive). thanks for the help
Jimh23 09-29-2009 04:51 PM
Re: Borken Speedo
Since your speedometer uses a 'sender' (called a speedometer pitot') the problem is probably a broken piece on it for attaching the tube. The fix appears to be purchasing a new Speedomer Pitot. The installation should be simple.
cometb 09-29-2009 04:59 PM
Re: Borken Speedo
Thanks! Where is the best place to purchase such an item?
WetWilly 09-29-2009 06:48 PM
Re: Borken Speedo
Hi cometb,
So it turns out you have an external pick-up. cool, any boating parts store local or on-line should carry one.
They're also commonly referred to as a "Speedometer Pick Up" and you should be able to pick one up for around $10 to $15.
You can try eBay, here's one really inexpensive: Click here.
Wholesale Marine.com: Click here.
Boaters World.com: Click here.
West Marine.com: Click here.
Good luck,
cometb 09-29-2009 07:13 PM
Re: Borken Speedo
Thanks!!
