-   -   93 5.0 LX Thunderbolt Alpha 1 Horsepower (http://www.mariahownersclub.com/forum/original-mariah-talk/3365-93-5-0-lx-thunderbolt-alpha-1-horsepower.html)
Snowaterdude 09-23-2009 06:39 PM
OK......I have been working hard all day.... Well, working hard surfing for the HP of my boat. I can't seem to find a right answer.....
My 93 MX200 Talari comes with the 5.0 LX (GM 305). Therefore, it has the 4 barrel carb (Rochester), so I think. From what I read, the 2 barrel carb came with the
"5.0 L" model, not the "LX".
Some web sites claim it has 220 hp, where others will say 230 hp. Does anyone know the horsepower of my boat???
Thanks !
Rick
indykoch 09-23-2009 09:09 PM
Re: 93 5.0 LX Thunderbolt Alpha 1 Horsepower
Here's the site I usually go to for HP ratings... http://home.earthlink.net/~nolen1/mercwot.htm
Unfortunately, yours isn't on there. My memory of that time was 220, but that was my senior year of high school / freshman year of college, so I obviously drowned a lot of brain cells!!!
Snowaterdude 09-24-2009 12:16 AM
I tell you man, I cant believe it. I spent all day at work looking for the ponies on this thing and I couldn't find anything concrete. You would think it would of been something easy to figure out....Oh well ! All I know is it has sufficient power for this 20 footer. Definitely not under power...All I need now are the smart tabs.....I am installing them this weekend.
spinks99 09-28-2009 02:15 AM
I have a 1995 5.0 LX Mercruiser with the original manual. It has 205 horse power.
Snowaterdude 09-28-2009 10:14 AM
WOW ! I am surprised......I had found quite a bit of info on the net and most of it said between 220 and 230.....I assume yours is a 4 Barrel carb as well, since it's the LX model? Rochester carb?
Snowaterdude 09-29-2009 10:26 AM
So, if the "LX" model has only 205HP, how many ponies does the "L" model have? Possibly lower than the 4.3 engine??????That would be odd!
spinks99 09-29-2009 09:10 PM
Hi Snowater dude,
According to the Mercruiser manual (copyright 1994) that came with my 1995 Mariah, propshaft horsepower in accordance with NMMA procedure using Marine Engine Rating Code SAE is as follows:
5.0 L-190
5.0 LX-205
5.7-235
350 Mag.-250
Could it be that propshaft horsepower is rated different than engine horsepower?
Snowaterdude 09-30-2009 12:21 AM
Originally Posted by spinks99 (Post 18543)
Hi Snowater dude,
5.0 L-190
5.0 LX-205
5.7-235
350 Mag.-250
I guess the book doesn't lie...I believe that shaft HP is lower than engine HP.....That might explain why some documentation will rate the engine closer to 220hp...
I remember in the 70's, OMC use to rate their outboard horsepower at the engine and Merc would rate it at the prop. The Merc would always perform better than the Evinrude/Johnson. A 50HP Evinrude for example was in fact only pushing roughly 45hp at the prop shaft.....Where the Merc throughly had 50hp at the prop...
