Electrical Problem with Gauges
I have no Tack,Oil pressure,or tempature readings on my Jubillee 214 merc.5.0 What should I look for first?
Re: Electrical Problem with Gauges
A fuse and a breaker might be a good start. Next need to check wiring diagram.
Hi Douglas, Captain Steve's right, sounds like you lost a common power or ground. WetWilly |
Looked at fuses all good. Moved and cleaned round connections.Still gauges not working. Does the ignition switch have anything to do with no power to gauges? Fuel,tack,oil pressure, and tempature gauges are the only ones not working.
Jim |
| All times are GMT. The time now is 03:56 PM. |
