'94 182 Barchetta Fuel Tank Capacity?
I looked at the brochure, but the lettering is blurry. It looks like it says 10 gallons, but that seems small for an 18' boat with a 4.3L V6 engine. Doing a search on "tank" in the subject shows other 18' Mariah boats with 30 ga. tanks.
How do you guys mix things like Sta-Bil with your fuel? It's best to put the additive in, then the fuel, so the additive gets mixed well during the fill. But if you don't know how much fuel you're going to put in... Are the fuel gauges at all linear? Thanks, Jim |
Re: '94 182 Barchetta Fuel Tank Capacity?
As for how accurate or linear are the fuel gauges, I believe ours is close but not exact, especially on the water because she sits a little bow up at rest, but that's OK because I follow the 1/3 rule (1/3 out, 1/3 back, 1/3 reserve) and I've yet to run out of gas in 26 years. ;) WetWilly :wink_thumbup: |
| All times are GMT. The time now is 02:41 PM. |
