-   -   Replacement battery for '99 Z222 Shabah? (http://www.mariahownersclub.com/forum/original-mariah-talk/2746-replacement-battery-99-z222-shabah.html)
GSlavens 06-15-2009 03:03 AM
I have a 1999 Mariah Z222 Shabah with a 1999 Mercruiser 250 hp 5.7L V8 engine. The battery that came with the boat is dead (or close enough to it), and I'm not even sure it was a good match to begin with. What would have come with the boat originally? Any info on CCA, MCA, reserve time, etc.?
Thanks!
aquaknot 06-15-2009 12:38 PM
Re: Replacement battery for '99 Z222 Shabah?
my original set up used two Trojan deep cycles. Currently I'm using mercruiser batteries which work fine. I still have the trojan batteries and can check the specs next weekend unless some one else knows
ShabahZ280 06-15-2009 08:38 PM
Is it a MPI engine? Last year when I was in the shop, I got a copy of a memo that said Mercruiser now recommends a minimum 750cca battery for use with the MPI system.
I went to the local wal-mart and bought two Everstart Marine batteries (group 29). $79 each, and a replacement warranty! At that price you can't go wrong. :wink_thumbup:
