-   -   Buzzer location? (http://www.mariahownersclub.com/forum/original-mariah-talk/2372-buzzer-location.html)
jkboliphant 04-24-2009 06:08 PM
Buzzer location?
Through more research I have found that Mercruiser has a buzzer alarms that should sound for certain malfunctioning conditions. I was not aware of this as mine obviously doesn't work. Can anyone out there tell me where this buzzer is physically located so that I can troubleshoot it? Thanks.
Z 202 04-24-2009 07:26 PM
Re: Buzzer location?
Not sure on yours, but on mine it's tied into the wiring in behind the panel where the stereo is.
ShabahZ280 04-24-2009 07:30 PM
1 Attachment(s)
It's located behind the dash. You can't miss it. I had to replace mine about two years ago. There's a company out of Columbus OH that makes the buzzers for Mercruiser. They're called Floyd Bell. The buzzer I used is from the M80 series. You can order it from them for about $10, or get the Mercruiser one for about $30.
I've attached a photo from the mercruiser parts diagrams for the 5.0L. It's labeled as number 12. This should help you identify it.
What I did was disconnect the wires for the buzzer, then connect to a 12v source, like the battery. If it squeals really loud, then it works, and it's time to start checking all your sensors. If not, then it needs to be replaced. I later found out the previous owner had disconnected it due to the fact it was constantly going off... nice huh? :mad:
2 OWNER MARIAH 04-26-2009 12:43 PM
On my 280 MCC it is located behind the shift and throttle panel.
Mine was constanly going of also, so I unhooked it until I could look for the problem. Never had any trouble with it until the repair shop put in a new starter for me. Well they must of un-hooked the water temp sensor next to the sarter and did'nt plug it back in.
Have not tried it yet in the water but I hope that is the problem:confused:
