info about Z216
Hi,
I have opportunity to buy Z216 year 1998, could you tel me what i need to check and look not to have bad things after, is my first boat , just I can see the REV not working its a big proble ? Regards, |
Hi MMarko,
In case you missed my reply to you in the Introduction forum, here it is again: Quote:
If it is not working it, first check is it have power (12Volts) going to it and the ground is good. If both check out, it could be due to corrosion with the "selector" switch. It is a small round dial located on the back side. Mark it's current setting then try and turn it back and forth several times and see if this helps. If you think that the REV (Tach) is still broken, you can see about sending it back to Faria (the maker) as it have a life time warranty on it. you can contact Faria here: To submit a Warranty Claim, go to our website; www.faria- instruments.com/warranty.php, select “Place a warranty claim here” and complete the form. If you have questions call Faria® Customer Service at 1-800-473-2742 weekdays 8:30 a.m. until 5:00 p.m. Eastern Time. One of our Marine Applications Specialists will review the problem with you in detail. WetWilly |
| All times are GMT. The time now is 01:22 PM. |
