Ski Locker Gas Shock
Has anyone sourced and replaced the gas shock that holds the ski locker hatch? My cylinder no longer supports the hatch, so I pulled the shock off. The part numbers are rubbed off, so I am unable to cross reference and find information regarding weight. The wording I can see says Spring Lift Corporation, but I cant read anything else. I would think this is a commonly available part, I just need to know how much force I need to buy. Thanks!
Hi Giffy,
I believe the this earlier thread may help you find what you're looking for, check out post #6 by rjobe: Click here. I would say a 20 to 30LB shock should be enough to hold your lid open. Good luck, WetWilly |
| All times are GMT. The time now is 01:05 PM. |
