| GregT |
06-05-2023 12:34 PM |
Re: Help
My initial thought is the wires are connected backwards on one of them, or you possibly have one that the connectors were re-done and reversed. First thing I would try is to take the one that is running opposite of what you want and stick two small sections of wiring between the connectors to switch them. If I remember correctly, they are set up with a male and female connecter end, so figure out how to temporarily connect them opposite to see if that fixes it, and if so, then simply put new connections on them.
