New owner questions
Old 01-29-2023, 05:02 PM   #11
Jid Thread Starter
Jid is currently offline
Send Jid:
Default Re: New owner questions
So it turns out the boat was winterized. Which makes some sense.
It still has a lot of weirdness. I fired it up and it smoked at operating temp for a long time. Like 20+ min. Since it never stopped I eventual out shut it down.
It revs alright. Some vibration when sitting on the trailer revving in neutral.
I really wish I could tell if the smoke was oil or not. There isn’t any water in the oil which is good. The outdrive doesn’t shift into gear smoothly so it likely needs maintenance. Although the gear lube looks like it was recently changed.
At this point the question is whether I’m willing to buy the boat and take on the project or just give it back. So many choices…. I mean it definitely needs work. Lots of little things. And the smoke…. That is a deal-breaker for me but knowing it was winterized means that -should- burn off…. But maybe it won’t.
  • Old 01-30-2023, 12:13 PM   #12
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    If the smoke is blueish-white and does not dissipate quickly is is burning oil. If it is white and dissipates very quickly then that is water vapor which is normal, the cooling water mixes with the hot exhaust gasses.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 01-30-2023, 12:52 PM   #13
    Jid Thread Starter
    Send Jid:
    Here is a video of the steam/smoke. Does this look like oil or steam/water? Note the engine had been running for 20 min at this point...
    https://youtu.be/wZjb6Zn5uJM
    Thoughts?
    Old 01-30-2023, 01:00 PM   #14
    Jid Thread Starter
    Send Jid:
    2nd video of smoke. Again, it had been running for 20 min or so.
    https://youtu.be/JImufIb-cFQ
    And the exhaust bellow is disconnected on the outdrive…. I need to re-connect that. It is quite obvious…
    Old 01-30-2023, 05:15 PM   #15
    GregT is online!
    My Model: Z275ST
    Send GregT:
    My 2 cents - doesn't look like it is burning oil from what I saw on the video. You should run it with the outdrive down, especially if you engage the gears. Being up like that is hell on the driveshaft u-joints from what I hear. Sounded nice though, and you have captains call which is fun.
    I did notice quite a bit of water under the engine, is your bilge pump working, or is that leakage while running?
    Old 01-31-2023, 12:35 PM   #16
    My Model: Z280
    I agree with GregT, that appears to be steam...not oil burning. Sounds good on video.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 02-02-2023, 04:23 AM   #17
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    I have a similar boat, a 99 Z202. 5.7 Chevy engine with Bravo 3 drive.
    I recently had to replace the fuel tank because of leakage. I was dreading it. Cutting up the floor was something I had done in other boats and was not looking forward to it.
    Nevertheless I started anyway. I love this boat. Nothing was getting in the way of me in enjoying it.
    To my surprise, it went well. I peeled back the carpet and to my delight I found the floor section was separately screwed down and easy to remove. With the floor out, I easily removed the old tank. Installing a new tank was a challenge because I had to find one similar in size and shape. I did and proceeded to do that. It went well.
    The thing that impressed me most is that this 24 year old boat had virtually no rot damage under the floor. I was shocked to say the least.
    Mariah was a high quality boat and very expensive. Not surprising it failed. Everyone wants cheap things....not me.
    Old 02-02-2023, 04:37 AM   #18
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Originally Posted by Jid View Post
    Sound advice.
    It is all about how much of a project I want. My wife has recently acquired a Sailrite machine and she has done some vinyl projects so she is willing to consider taking this on. I can do any of the engine work… just trying to figure out if I have the time.
    One thing I forgot to check is the risers. They look original so there could be a blockage. But I do want to check the leak down too. I could do compression but that isn’t as much of a concern as the head gaskets. And with the back cover off the boat, a head gasket wouldn’t be hard. Plenty of clearance.
    The current owner was hoping to get 4k including the beat up trailer. Given what I know right now that is too much given the current condition. But I need to dig deeper.
    Did I mention it doesn’t shift smoothly? Need to pull the Alpha at some point too… if I dig that deep.
    That could be a problem with the shift interrupter. Usually a simple fix. It is problematic when shifting out of gear?
    Your video looks pristine. Water vapor steam..normal. And the A outdrive looks pristine also.
    Pulling the outdrive is something we all do about every 3 years...routine inspection.
    Jid likes this.
    Old 02-02-2023, 11:53 AM   #19
    My Model: Z280
    Hard shifting on an Alpha is usually the cable that goes from the shifter plate on the engine thru the transom plate to the shift mechanism on the bell housing. It most likely needs to be replaced.
    Jid likes this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 02-02-2023, 12:02 PM   #20
    Jid Thread Starter
    Send Jid:
    I was planning on a lake test this weekend but with a freeze warning for tonight and tomorrow…. That may not happen. One more week to wait.
    I really appreciate all the feedback and encouragement. The more I hear, the more I may want to take on the project. Now to convince the wife to try the vinyl…
    New owner of 2150 xlc, few questions oleblue Original Mariah Talk 4 08-22-2016 03:08 PM
    New Mariah Owner with questions! GravyTrain210 General Maintenance 10 05-01-2013 06:05 PM
    New Mariah owner with some questions stuartm77 Original Mariah Talk 2 07-11-2011 01:39 PM
    new owner has questions geiffert Original Mariah Talk 3 05-28-2008 02:34 AM
    New owner with questions turfguy99 Original Mariah Talk 3 05-05-2008 01:30 AM
    Total Members: 18,510
    Total Threads: 12,950
    There are 152 users
