Warning beep
Old 10-14-2021, 01:58 AM   #1
markyta is currently offline
Status: Silver Contributor
My Model: Diablo 18
My Engine: 4.3 Merc
Send markyta:
Thumbs up Warning beep
I know when you turn the key on, a long beep should happen. Does this beep also signal when there is a failure (oil pressure, overheating etc.)?
Thank you
  • Old 10-14-2021, 02:30 AM   #2
    Default Re: Warning beep
    Yes. If it continues or starts beeping during operation you have an issue with overheating, low out-drive oil level or oil pressure in the engine. MOST of the time, it is due to low outdrive oil levels. Check your reservoir.
    Old 10-14-2021, 09:41 AM   #3
    My Model: Diablo 18
    My Engine: 4.3 Merc
    Send markyta:
    Thank you
    Need help. BEEP BEEP every 60 Seconds! Importcars.at Sea Fox - Mariah Talk 6 08-08-2017 04:27 AM
    audio warning system mszola Introductions 2 03-22-2016 01:52 AM
    Mercruiser Warning System & Beep Codes mikeyt Mercury MerCruiser 0 05-16-2013 02:37 AM
    warning alarm only beeps twice. Brad Mercury MerCruiser 4 04-24-2011 03:07 AM
    7.4L MPI Engine Warning Alarm ShabahZ280 Mercury MerCruiser 13 02-09-2008 07:39 PM
    Total Members: 18,520
    Total Threads: 12,955
    There are 151 users
