| Sparks&Stripes |
09-20-2021 11:10 AM |
Re: 94 talari courtesy lights wiring
I would tear apart the dash and look for wires that may have fallen off. Each should have one power wire that sends 12v to the circuit when the switch is on. People make a mess of things sometimes unfortunately. All the switches should be wired the same pretty much though as far as the power and grounds going to them, The only difference will be the output wire. Many Mariah's had accessory switches added that were all wired up except they didn't have any output wires on them, there were there for the owners to add accessories easily if needed.
