Transom Mounted Trim Switch
Did any Mariah boats come stock with a transom mounted trim switch? I just bought a '95 Z275 and it doesn't have one.... Seems like a small thing to add that really helps when you are working on the out drive. After changing the gear oil today, I will be adding one soon.
Re: Transom Mounted Trim Switch
My 98 Jubilee has one. They are nice. I believe you can buy one from Merc and they are plug and play for those that wish to add it on. All boats should have them!
1 Attachment(s)
The later boats had them but they were optional in the earlier boats. S&S is correct though, you can buy a plug & play transom mounted switch which is fairly easy to install. Here's the wiring diagram...
Mine didn't have a transom mounted trim switch either. I purchased a plug and play switch and mounted it. I also mounted a momentary double throw single pole switch in my anchor locker (in the bow) and wired it into the trim solenoids so i can raise my outdrive into trailer position while standing on my trailer hitch when loading at the ramp.
I bought a spdt momentary switch and wired to the trim solenoids. One of many problems solved.....lol
| All times are GMT. The time now is 09:58 PM. |
