| Hudson River Steve |
05-23-2021 11:55 AM |
Re: 97Z276 Dash lights
There is a dimmer module built into the back of the "Dimmer" switch that controls the brightness of the blacklights on the gages. Try pushing the dimmer button up a number of times to increase the backlight intensity. If that does not work, your dimmer module may be shot. I had to replace mine. Believe I used a separate module from Blue Seas as the original dimmer from Carling Switch was no longer available.
