-   -   bilge pump (http://www.mariahownersclub.com/forum/original-mariah-talk/13639-bilge-pump.html)
wejaz28 04-25-2021 09:50 PM
bilge pump
96' Shabah...Does the bilge pump run when you flip the dash switch to on, or only when it senses water?
When i flip the switch, I don't hear it turn on.
mikeyt 04-25-2021 11:06 PM
Re: bilge pump
Then its not working properly. Go back and lift the float switch & see if it works. And while you're there, check the wiring connections and see if there is power. And check the fuse under the dash.
wejaz28 04-26-2021 03:41 AM
Re: bilge pump
Thanks. A place to start.
