-   -   need info on boat weight (http://www.mariahownersclub.com/forum/original-mariah-talk/1351-need-info-boat-weight.html)
jsk9675 06-27-2008 09:08 PM
I need to replace my current boat lift and can not find info on the weight of my boat its' a 1997 209 Talari with a 5.7L 2 barrel
any help would be appreciated
WetWilly 06-28-2008 06:01 AM
Hi jsk9675,
The 97' 209 weighs in at about 2850lbs for the 4.3L, so let's error on the safe side and say your Talari weighs in around 2950lbs.
Heavier if you have a lot of gear (toys) stowed aboard. :wink_thumbup:
Captain Steve 07-01-2008 01:53 AM
For what it's worth, my 1997 Z210 Shabah with a 5.7LX Alpha weighs in at 4,600 pounds on its Chariot tandem trailer. That's on a certified scale, detached from the tow vehicle. I think the trailer is about 1,000, so that leaves the boat at about 3,600 pounds, which is heavier than I would have guessed.
Regards,
WetWilly 07-01-2008 07:38 AM
Wow, Captain Steve, time to put your Shabah on a diet!!! :rolling_laugh:
But truthfully, the 209 and the 210 are supposed to weight the same so that does seem a little heavier that she should be, unless you had a lot of gas and play toys in her... :rolleyes:
indykoch 07-01-2008 04:29 PM
Actually, I've heard tandem trailers for 20'-22' boats weigh about 1250-1300 lbs. Taking gas, toys, larger engine than standard, etc. into consideration and I think you're about right.
