-   -   Talari 210 5.0L performance/top speed question (http://www.mariahownersclub.com/forum/original-mariah-talk/13091-talari-210-5-0l-performance-top-speed-question.html)
ryderx 08-30-2020 06:02 PM
Hello,
I have recently purchased this boat and have some general questions about performance. The first time on the lake I could not get over 8MPH. This was due to a loose distributor cap and timing being WAY off. After getting it adjusted properly the boat would hit 28MPH. I know there is a lot of variables to speed however, does this seem to be in the right ballpark for the 5.0L?
Lancer 08-30-2020 06:21 PM
Re: Talari 210 5.0L performance/top speed question
what's the rpm at 28 mph. I don't have that motor so I'm guessing you need to be around 5000 rpm. someone with that power package will verify for you.
ryderx 08-30-2020 06:46 PM
I will need to check that next time its on the lake, but i think it was 4000ish +-250 RPM. For sure not near 5000RPM.
Hudson River Steve 08-30-2020 08:18 PM
The WOT for a 5.0 is 4400 to 4800 RPM, so you seem a little low. I do not have your boat or power package but I would expect speeds in the high 40's.
mikeyt 08-30-2020 08:44 PM
As Steve says, your WOT rpm range should be between 4400 and 4800 and you should have a top speed in the high 40's with that boat /motor combo. Prop for that motor should be a 19" pitch. One thing i would do to check that your tach is reading correctly is to access the back of the tach and spin that little wheel around 5-6 times then set it on "8 cyl". Based on what you're saying though, i suspect you have other issues that need to be investigated.
