-   -   Mariah Shabah major advice needed (sad story) (http://www.mariahownersclub.com/forum/original-mariah-talk/12471-mariah-shabah-major-advice-needed-sad-story.html)
TN_Diablo 05-26-2020 01:50 PM
Re: Mariah Shabah major advice needed (sad story)
Originally Posted by Cappy (Post 66897)
Outdrive was not touched, don't think. Just the engine.
Well if they had it and didn't recommend you put in a new pump and fluid they should have. Hopefully they did do that as minimum maintenance on a drive of unknown service history.
Cappy 05-27-2020 07:33 PM
Looking at the detail of the rebuild they replaced the stern drive pump and fluid.
Cappy 06-04-2020 01:14 AM
Turns out they did not rebuild the carburetor. It ran pretty rough at slower cruising speed.
Also, the ear splitting engine warning bell was constantly going off ruining the serenity. Even with the engine off and the key turn to turn on the electrical power it starts to go off. No clue what it could be. Hopefully just a bad sensor.
So back at the marina for a $380 carburetor rebuild and diagnosis of the warning bell.
It is so fun having a boat for those minutes they run smoothly.
