-   -   Shabah Z202 Power Trim Fuse Location (http://www.mariahownersclub.com/forum/original-mariah-talk/12406-shabah-z202-power-trim-fuse-location.html)
Hlange 07-07-2019 01:28 PM
Anyone know where the fuse that supports the power trim is located? It is not on the main panel under the helm those appear to be breakers. I have nothing on either trim switch, and it just stopped working after my last trip, motor is down and on a lift. 1st step in fixing this is supposed to be checking the fuse, anyone know where it is located?
Mwb712 07-07-2019 01:49 PM
Re: Shabah Z202 Power Trim Fuse Location
On my 1994 Barchetta, I have a separate fused block located on the inside Starboard side opposite of the throttle close to the bow. Pain to get to, found it by accident.
Sent from my iPad using Tapatalk
mikeyt 07-07-2019 02:30 PM
The other spot for a fuse block was on the transom just behind the rear starboard side seat.
Here's a link to a troubleshooting guide: http://www.mariahownersclub.com/foru...or-system.html
