Z255 Shabah NAV Lights Not Working
Old 02-27-2019, 05:17 PM   #1
SeattleRemedy is currently offline
My Model: Z255 Shabah
My Engine: 7.1 Bravo III
Send SeattleRemedy:
Default Z255 Shabah NAV Lights Not Working
Both lights out-bulbs are good. The stern light works in both positions. Could it be the switch? I just ordered one so we'll see. Dumb question: my fuse panel under the cockpit console- are those GFCI type fuses...ie: they just "pop" out and you reseat them? In other words- they aren't replaceable?
Thanks in advance!
  • Old 03-11-2019, 02:49 AM   #2
    Default Re: Z255 Shabah NAV Lights Not Working
    You're correct, the breakers are just resettable, they pop out and you push them back in to reset. Hopefully your issue may have just been a bad switch or maybe the contacts got dirty too. I had heard that Mariah did have an issue with corrosion on their switches and wire connects, due to the rapid breakdown of a dielectric grease they used, and once it broke down, the switch contacts could corrode easier. Sometimes just unplugging the contacts and replugging them back in can clean them enough to get them functional again. Let us know if you were able to get them running again!
    Old 03-11-2019, 09:58 PM   #3
    Send SeattleRemedy:
    Thanks Chris...ended up being the switch. All good now
    Courtesy lights not working rosco0000 Introductions 6 10-25-2017 12:28 AM
    nav lights and gauge lights not working lumbercitybravest Original Mariah Talk 5 08-13-2013 05:11 PM
    Navagation lights not working Mariah on the bay Original Mariah Talk 1 06-12-2012 10:13 AM
    Z255 Shabah fritz49 Original Mariah Talk 0 03-14-2011 06:10 PM
    Cabin Lights not working Daxgirl Original Mariah Talk 1 04-28-2009 04:07 AM
    Total Members: 18,525
    Total Threads: 12,958
    There are 141 users
