Fuel Filter/Water Separator
Old 09-11-2018, 10:31 PM   #11
pole trick is currently offline
My Model: 180 Shabah
My Engine: 4.3 Merc
Send pole trick:
Default Re: Fuel Filter/Water Separator
The blower is to remove any fuel fumes that may of built up in engine area..these can explode when engine started. Run blower 3 to 5 min before starting or lift rear cover to vent any fumes. It has nothing to do with temp.it all about not having fumes build up. I have my the depth finder/water temp sensor glued to bottom of inside the boat under engine..on hot day engine compartment usually 89 to 115 degrees when running. Inboard/car type engines usually run between 140 and 160 depending on setup.. should not of been vapor lock.. if pump is dry from sitting months or years and 100% dry or ran tank out of gas they may not prime engine until fuel is pushed up pump to get it wet again.
  • Old 10-05-2018, 05:52 AM   #12
    Macker29 is currently offline
    My Model: Diablo
    My Engine: 4.3 Mercruiser
    Send Macker29:
    Originally Posted by Motoxxx43 View Post
    Just switched to these this season. So far I like it. Was running Wix without issues. Just found the Sierra 10 micron for a better price.
    Wix filters are good...but definitely expensive. Oreilly Auto Parts usually stocks them.
    Tried to install new fuel filter/separator and ensuing problems GaryDoug Original Mariah Talk 3 04-18-2017 02:58 PM
    Anyone else having trouble removing fuel separator? donly1 Original Mariah Talk 2 04-29-2014 06:17 PM
    water separator and fuel filter newbie Original Mariah Talk 20 06-18-2013 04:57 PM
    Fuel / Water Separator Filter Conversion Dredd Projects 0 04-27-2010 07:30 PM
    adding a water separating fuel filter jeffryb Sea Fox - Mariah Talk 0 01-18-2010 07:57 PM
    Total Members: 18,524
    Total Threads: 12,958
    There are 144 users
