-   -   Shabah Z202 (http://www.mariahownersclub.com/forum/original-mariah-talk/12037-shabah-z202.html)
Mariahsteve12 06-27-2018 08:46 PM
Shabah Z202
Mariahsteve12
I have a Shabah Z202 Alpha One 5.7. Does anyone know what carburetor this boat uses? Only numbers were on the base of the carb and it seems to be a Weber manual choke. I need to order one but I can't order with those numbers. I have read where I could probably use an Edelbrock carb but I would have to change linkage and I'd really like to stay with the original carb if possible. Thanks in advance.
bloyet03 06-27-2018 09:27 PM
Re: Shabah Z202
Originally Posted by Mariahsteve12 (Post 64739)
Mariahsteve12
Back, left, bottom side of the engine should have an engine serial number plate. It was a PITA to get at on my Jubilee. Mercury has a parts manual online that with that number you should be able to look it up.
Sent from my Moto Z (2) using Tapatalk
mikeyt 06-28-2018 12:27 AM
Re: Shabah Z202
The number should be stamped right on the base of the carburetor. My 180 used a Weber/Carter 9600S 4 bbl and the 9600 was clearly stamped on it.
Mariahsteve12 06-29-2018 02:24 AM
Re: Shabah Z202
Thanks guys. I found it. Now to find one...............
