-   -   Need new batteries this year have questions (http://www.mariahownersclub.com/forum/original-mariah-talk/11919-need-new-batteries-year-have-questions.html)
tpdtopcop 04-09-2018 12:00 AM
Hi all.
Bought my Z255 with marine deep cycle batteries and I have installed the blue seas dual setup. I was on another forum and they were discussing starting battery and house battery and that the starting battery shouldn’t be a deep cycle? Does this sound right. I was always under the impression that two marine deep cycles were all that was needed?
mikeyt 04-09-2018 12:33 AM
Re: Need new batteries this year have questions
A starting battery provides more CCA's and less reserve than a similar sized deep cycle battery. Starting batteries are designed to provide quick strong bursts of energy and then be quickly topped up by your alternator. While a Deep cycle battery can provide that brief burst of energy and will work as a starter, they are intended to provide consistent voltage over a longer period of time and are intended mainly for use with marine accessories such as stereo systems, boat electrics etc. Deep cycle batteries can also be drawn down in their voltage and be re-charged more often than a starting battery. And, when recharging a deep cycle battery, you should do it over a longer period of time at a lower voltage or you will shorten the life of the deep cycle battery.
tpdtopcop 04-09-2018 01:46 PM
Ok so the starting battery should be an automotive battery and the house should be a marine deep cycle?
mikeyt 04-12-2018 11:58 AM
Yes...
